    Aug 2001
    ok, i could use some help.
    i want to edit the menu on a episode disc. i have tried pgcedit and vobblanker
    but no luck. i tried to some searching but agin no luck.
    if anyone has an easy guide. please help.
    now i did create a disc with only 2 episodes but the orginial menu has 4 selections on it.
    all i want to do is hide those two that arent on there.
    thanks for any help.
  2. Take a look at MenuEdit
    -drj
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
    Aug 2001
    hey thanks this looks sweet.
    i remember reading bout it awhile back but had no use for it at the time.
    thanks again.
    crazydrve
    Apr 2004
    Miskatonic U
    You can remove the links so they can't be selected, but you may not be able to remove all the screen references if they are part of the background graphics (which they often are)
    Read my blog here.
  5. Ifoedit. Photoshop to author a new menu. Re-author DVD. Presto, problem solved.
  6. You can remove the links with DVD Remake Pro also.
    Aug 2001
    how would i use ifoedit and photoshope to author a new menu.
    so there is now way to extract just the menu.
    i was able to remove links but i dont like that the episodes still show up on the menu.
    any help is appreciated.
