I have a AVI video of 650 MB where the sound follows the video with a 8 seconds delay throughout the video. How can I fix it ? I tried Virtualdub but the outcome is extremely huge, could not count how many GB !
Is there an easy way to sync audio and video ?
sounds like you resave the video wrong if you are just trying to sync the video select direct stream copy from the video menu,this makes and exact copy,you probably were resaving a new video uncompressed.creating a verry large file.you cannot due a direct stream copy if you apply any filters.direct stream resaves the video with a different frame rate to sync audio. 8 seconds is a big gap sounds like a film rate vs. ntsc.had that happen last week,good luck
No, there is no easy way.
In virtualDub click Video->DirectStreamCopy. Then the file will be 650 MB again. The default is Full Processing which give you uncompressed video that is huge in size. -
As suggested, make sure that Video->Direct Stream Copy is selected. In Audio select Interleaving. Don't change any settings except the Delay. Enter the amount (posative or negative) in ms that you need to correct by. Save the results and test.
Read my blog here.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 22:25 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 13:30
