I've got literally 100's of vcd-format mpeg files, and I want them to all have the same general volume. Is there a program I can use to just run the mpegs through it, and be done with them?
I'm very familiar with the TMPGenc family, and I know they have a volume adjustment setting, but unless I'm mistaken, they seem to only be able to increase or decrease the volume by a fixed percentage. What I want to do, specifically, is set all mpegs to the same exact decibal level.
As always, THANK YOU!!
-Chauncey
I appreciate your trying to help me, Soopafresh, but I'm a little confused & want to make sure I understand so I don't accidentally mess up my mpegs.
I unzipped BeSplitv0.9b6.zip into a directory & then put your norm.bat file in the same directory.
Next, I should split the mpegs into separate audio & video files with my TMPGenc Plus.
Then, take the resulting mp2 files & use the norm.bat file on the whole lot of them, to normalize them to each other.
Then use TMPGenc Plus to put the audio & video files back together into an mpeg again.
Am I correct?-Chauncey -
About normalizing mp2 audio without reencoding see:
https://www.videohelp.com/forum/viewtopic.php?t=267760&sid=1236fbc0138715ffd9d82eafe2aedbd6
what is the best way to normalize an ac3 audio?
By sgbd in forum Video ConversionReplies: 1Last Post: 24th Sep 2010, 14:46 -
how do I normalize too silent audio
By Aivc in forum AudioReplies: 1Last Post: 15th Apr 2010, 13:30 -
Is there a way to batch normalize audio of MPG2
By mehnihma in forum AudioReplies: 3Last Post: 6th Mar 2010, 00:15 -
Normalize audio - batch possible?
By lj01 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2008, 19:19 -
Normalize AC3 Audio
By dridge in forum AudioReplies: 3Last Post: 26th Nov 2007, 12:12
