I have an avi file that is sync'd up perfectly in whole. When I split it the file is always out of sync. I;m using the scroll bar ansd "Next Key Frame" to find my cutting point. What am I dong wrong. Any help would be appreciated. To those with the answers, I thank you
Is the audio a Variable Bit Rate MP3? If so, demux it and convert it into a constant bit rate file. Remux it back into the file. Hope that works for you.
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 16:44 -
Problems with splitting AVI in ffmpeg
By avalk in forum ProgrammingReplies: 0Last Post: 14th Feb 2011, 05:13 -
Yamb - Problems While Splitting the MP4 File
By Cunhambebe in forum Newbie / General discussionsReplies: 11Last Post: 25th Jun 2009, 22:58 -
Splitting avi file
By tryst1 in forum EditingReplies: 2Last Post: 15th Nov 2007, 03:33 -
VirtualDubMod Splitting problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2007, 17:20
