I have a Sony DSC-P93 that records MPEG-VX (640x480 30fps MPEG-1 audio 32000mhz-mono).
In order for my DVD player (Philips 642) to recognize the files (it doesn't recognize this raw MPEG stream at all), I thought I had to convert them to a useable format, VCD or SVCD compliant files, but I don't.
I tried to re-write the header to a compliant VCD or SVCD with TMPEG but the file doesn't play. Plus if I import into Nero to burn, it wants to convert the file.
I tried to re-write the header to be an XVCD or XSVCD but it doesn't play either.
But, if I open the videofile in soundforge and then save as an SVCD compliant MPEG-2, it plays fine and imports fine into programs to create an SVCD. Plus there is no difference in quality. I do not think that soundforge is converting the videofile, but what is it doing?
My long winded question is, what is soundforge doing with my videofile?
Thanks.
Soundforge may be rewriting the audio as compliant and/or correcting some header information.
Read my blog here.
Was I supposed to get soundforge 10 with Vegas 9.0?
By solarblast in forum AudioReplies: 0Last Post: 13th Mar 2011, 22:50 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00 -
Copying CD track with Vegas, SoundForge, Nero, ...?
By solarblast in forum AudioReplies: 8Last Post: 29th Aug 2009, 01:21 -
How To Replace Audio with CDAudio on MusicVideos(Soundforge)
By Sartori in forum User guidesReplies: 5Last Post: 19th Jan 2009, 19:41 -
avi sound editing in Soundforge
By maxWsax in forum AudioReplies: 6Last Post: 31st Mar 2008, 02:54
