I'm currently using DVD Workshop 2 trial but it only allows up to 20 chapters.
Are there any similar progs (similar in flexability, I found Workshop to be everything i need minus this chapters issue) that allow many more?
Thank you.
The DVD WS 2.x Trial has the following limitations:
This Trial Program has the following limitations:
The Motion Menu feature is limited to 30 seconds.
Maximum of 30 menus for one project.
Maximum of 10 slideshow or video titles for one project.
Maximum of 99 images for one slideshow title.
Maximum of 20 chapter points for one video clip.
No support for Dolby® Digital AC-3 audio files.
No User Guide in PDF format included.
Less content included.
No utilities and drivers included.
Can you split your video into separate clips. Each one should be able to have 20 chapters.George -
GeorgeW - Thanks for that info.
andkiich - If I'd known about the limitations I may have done.
Thanks again GeorgeW.
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 15:03 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 21:45 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 16:37 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 10:21 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 14:45
