How can I add chapters to a Divx file?
Results 1 to 13 of 13
When it sounds too good to be true, it usually is!!
I ask because I use my Pocket PC to watch videos. The program I use to see videos is Betaplayer and it has an option to jump to chapters.
When it sounds too good to be true, it usually is!! -
thanks i will take a look
I didn't think that beta player supported the .divx format? But I guess if you are already using it..
But yes it does support chapters, which you can add when you are creating your files via fuse.
Anyway, if you are willing to change containers it should support mkv or ogm, both of which support chapters fine. mp4 would be another option maybe. -
Thanks for your reply...Originally Posted by celtic_druid
Is fuse Fair Use??When it sounds too good to be true, it usually is!! -
No. It is a commandline app released by DivX Networks for creating DivX files with chapters, menu's, etc.
How are you creating your DivX files then if not via fuse? As far as I know it is the only app available. -
I use FairUse Wizard and/or PocketDivXEncoder.
Ahh, so you meant avi or ogm then? I believe they are the output formats of those apps. DivX as a format is something else. Basically some further hacks to avi. Although it is also a video codec that can be used in various containes.
Do either of those apps support importing chapter lists? If so enable creating them when decrypting with DVD Decrypter or create them afterwards with something like chapterxtractor (think that is the name). Then you should be able to output an ogm complete with chapters. -
Thanks I will give this a try tonight.
Hi everyone!
Celtic druid, can you tell me how to add chapters using fuse?
I use fuse to mux xsub subtitles, but didnt knew about the chapter function
i think the divx container is the best container because it can be played back on any divx certified player and ogm or mkv can only be watched on the pc.
thanks -
No idea. However according to the DivX Labs page it is possible. I guess you need some kind of XML file.
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 05:14 -
It is possible to add chapters in divx dvd ? subtitles ?
By carl25 in forum Authoring (DVD)Replies: 7Last Post: 2nd Jul 2009, 23:06 -
Need to add chapters to a 3GP file
By fredsp in forum Video ConversionReplies: 4Last Post: 22nd May 2008, 03:22 -
I can't add subs to a DivX file I have for some reason...
By darkzero297 in forum SubtitleReplies: 1Last Post: 4th Jul 2007, 18:41
