Was there an increase in speed between versions .64 and .84? I just upgraded last night and my total conversion time went from 5 hours to 2 hours. This is with CCE set on 2 passes.
I usually sleep when using DVD rebuilder / CCE, but I haven't noticed any reduction in time. I think I would have noticed a three hour time savings though.
NEC ND3500A/G
Unproper and proud of it -
i upgraded from v71 to v84
using 5 pass on a p4 2.8ht
and its like 7 hours
was about the same before -
Maybe its my memory. I thought it took longer as I too set it to go over night.
the speed isn't based on rebuilder itself, its based on the encoder primarily. did you use the same source disk, and same process setup?
No I think I know what happened. I only used Rebuilder in the past for long movies and fulf disk backups. it has been so long since I used that my memory was backing up 3 hour movies. This time I did "The incredibles" which is far shorter, therefore less encoding time. I'm going to get some sleep now so I can start to think clearer for now on.
DVD Rebuilder overflow
By RickyPinxt in forum Video ConversionReplies: 14Last Post: 27th Apr 2011, 14:43 -
DVD in BD Rebuilder!!!
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 18th Aug 2009, 10:22 -
dvd rebuilder
By dvd1304 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2009, 12:31 -
DVD Rebuilder (free)
By maja_the_bee in forum DVD RippingReplies: 1Last Post: 27th Jul 2008, 10:12 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
