I'm hunting like a beaver for a stand alone (Whether Portable or rackmountable) MP3 recorder.
I currently have a Nomad Jukebox 3 with 40Gb hard drive which works superbly, and if possible, woiuld like another, but on searching, it is unfortunately not available anymore.
Does anyone know of a good quality mp3 recorder, must record at 320kbps for more than 7 hours continuously. from a stereo source.
Whether onto a HDD or a large (ie 2Gb) memory card or internal storage.
Also any companies that will be able to deliver within the UK PDQ.
Any help much appreciated.
I think it's the wrong forum, but anyway.
Marantz PMD671 (with 2GB CF memory card or microdrive card):
http://d-mpro.com/users/folder.asp?FolderID=3689&Tab=Data+Sheet -
My iRiver H-140 can do this.
I can record directly to MP3 at any number of bitrates (up to 320 kbps) at a sample rate of 22/32/44.1 kHz from either inbuilt mic, external mic, line-in or optical-in.
It has a 40 Gb HDD.
I don't know if you can record for 7 hours continuously though... I've never tried that.
Regards.Michael Tam
w: Morsels of Evidence -
The iRiver H140 manual sais:
"Recording is automatically stopped if:
... When the recorded MP3 file size is over 195MB".
Source (open file with Acrobat Reader, then go to page 35):
http://www.iriver.com/html/admin/etc/adet_download_process.asp?fileName=H140%20English...WNLOAD_UP_PATH
So, unfortunately a continuously 7 hour recording @ 320 kbps is not possible with that recorder. That, and the fact that the rechargable batteries cannot be exchanged easily, are the reasons why I would never buy this device. -
You are not going to find any portable HDD based MP3 player with replaceable batteries...
Perhaps you should invest in a cheap notebook or ultraportable and use a high quality USB soundcard or CardBus soundcard...
Regards.Michael Tam
Does this mp3 recorder exist?
By Theresa in forum Portable VideoReplies: 2Last Post: 22nd Jan 2009, 14:40 -
replace audio with quality MP3 recording from other recorder
By daka in forum AudioReplies: 5Last Post: 26th Jun 2008, 21:08 -
DVD-recorder with good mp3 features
By nille in forum DVD & Blu-ray RecordersReplies: 25Last Post: 7th Dec 2007, 08:43 -
MP3 Recorder as Remote Sound Pickup
By markannab in forum AudioReplies: 1Last Post: 3rd Jun 2007, 12:15
