Hi everyone,
I'm trying to find inkjet printable cardboard dvd sleeves. A long time ago they used to sell them at Circuit City in packs of 25 - they were front and back printable (I only need to print the front), paperboard thickness (a little thicker would be nice) - and were perforated, so after printing you just removed them at the perforation, folded in half and folded over/sealed the side flaps.
The result is sort of like a carboard/paperboard version of the type of sleeve that Netflix dvd's come in (the actual sleeve, not the mailing envelope), or like a cardboard dvd/cd mailer without the top flap. Actually, the top flap would't be a problem, and would probably provide extra protection from dust, etc. - as long as the flap is the tuck-in type and not the sticky-seal type, and the front is printable.
Anone know where I can find these? Large quantity puchase is OK, I need about 500.
Thanks for any info,
Roy
Meritline has a selection of DVD Mailers, including a paperboard version that you can print on and then fold into an envelope.
http://www.meritline.com/cd-dvd-case-mailer.html
CD Dimensions has some cardboard mailers if you want something stiffer.
http://www.cddimensions.com/cd_dvd_packaging/mailers.asp
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Check out the custom cd sleeves at http://www.neato.com/neato_prodtest_sub.asp?class%5Fid=%5FCDSLEEVE&cat=%5FSTORAGE&mscs...63KJ6SF1V80CF4. Is that what you are looking for?
It doesn't matter who you vote for. The government always gets in. -
Thanks!Originally Posted by Laddydaddy
Exactly what I'm looking for:
Custom CD Sleeves
For InkJet Printers
Adhesive Strips For Easy Assembly!
Fast - Easy to print, fold and assemble
Save space - less than 20% thickness of standard jewel cases
Archive - quality acid-free stock protects and will not scratch disc surfaces
Perforated for complete and easy separation from printing sheet
Scored for crisp and accurate folding
1 CD Sleeve per Sheet
now, anyone know where to purchase a generic or store brand for less $$ in large quantity?
Roy
Are plastic sleeves good for DVds?
By cynikalhedonist in forum MediaReplies: 10Last Post: 28th Feb 2011, 02:12 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:39 -
DVD plastic sleeves
By danielmak in forum MediaReplies: 2Last Post: 8th Mar 2010, 04:51 -
any sleeves better than tyvek?
By spiffy in forum MediaReplies: 3Last Post: 20th Aug 2007, 13:15 -
Create your own cardboard or plastic DVD slip cases?
By lordsmurf in forum MediaReplies: 3Last Post: 23rd Jun 2007, 18:31
