I have a pioneer a09, recently i upgraded the firmware.,ever since the upgrade the disks i have been useing for a month no longer work.i am useing nero to burn 6.0.0.23.it tells me the compilation is to large for this disc,please insert a higher capacity disk.before the reflash these discs burned fine.
if im not posting in the right forum sorry.
thanks for any help,
Donrenee
update nero,thats an older version,so it really isnt up to recognise the writer.
and get the newest firmware for that writer,im sure there up to version 1.40 now.that solves a few problems too.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant. -
The l firmware i upgraded to is 1.40 if my version of nero is bundle software will it let me upgrade,what about a serial key will i need one.
thanks,
Donrenee -
You can update Nero to 6.6. Just download and install.
http://ww2.nero.com/enu/nero-up.php -
I just had some problems with the updated Nero Vision Express and found out at cdfreaks.com about a patch to fix. Thought you might get into the same situation.
http://ww2.nero.com/enu/Patch_for_NVE3.html
Lite-on DD-A100GX firmware upgrade?
By perceptionist in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Feb 2011, 04:45 -
DVDR-3380 Firmware upgrade
By Spideray in forum DVD RippingReplies: 2Last Post: 25th Jan 2009, 03:13 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 19:45 -
Pioneer DVR-115D Firmware Upgrade
By G13 in forum MacReplies: 3Last Post: 23rd Apr 2008, 02:14 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 01:33
