i saw many people got dvp642 and it is really cheap, but i also saw negative comments about it.
so, any real great player could support GMC and Qpel?
i dont want to waste time to change my files.
Results 1 to 9 of 9
read
https://www.videohelp.com/forum/viewtopic.php?p=1277438#1277438
and
http://www.divxtest.com/resultats.php3
or build a htpc. -
I believe the Mediatek chipset based players (e.g., I have a Zensonic 330) support both Q-Pel and GMC.
Regards.Michael Tam
w: Morsels of Evidence -
vitualis, are you sure your player could play Xvid file with QPEL and GMC?
Yes.
There is some limitation with GMC, however (2 warp points or something like that).
Regards.Michael Tam
o, still the problem, but that is a much better reslut.
where did you get it? from internet shopping?
by the way, dose it support dvd-DL?(8GB) -
Yes, I did get it off the internet.
I feel that Zensonic may be an Australian brand, however.
Other distributors may OEM the same player, however. In any case, I believe that DivX/DVD players based on MediaTek chipsets should support both GMC and Q-Pel (and less than 2 consecutive B-frames).
http://www.zensonic.com
As for DL-media... I can't say. I haven't tried. However, it does read my CD-R/-RW, DVD-R/+R discs perfectly.
Regards.Michael Tam
it seems like i couldn't get a good player from where i live. Australia is a real good place and produce goods.
maybe after several months, there will have a lot of new divx player with new functions, i'd better keep money right now.
all in all, thank you so much for your explanation. -
Rjtech's latest players support QPEL and GMC:
http://www.rjtech.net/p_divx.html
Best BluRay player with MKV, DivX, XVID, etc... support. ADVICE PLEASE!
By szabo_77 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Apr 2011, 17:13 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
How to reconvert an AVI with AutoGK, remove QPEL, GMC etc
By Baldrick in forum User guidesReplies: 35Last Post: 10th Jan 2010, 23:00 -
Philips DV624/37 AVI (XviD) Problems (Not QPEL/GMC)-could it be the codec?
By wingalls in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 01:13 -
XviD: Qpel, GMC, Max consecutive B-VOPs, and N-VOP ??
By GangstaRap in forum Video ConversionReplies: 17Last Post: 20th May 2007, 04:59
