    Nov 2004
    I have three early chapters in a 1.5hr program. I want those three chapters on the menu but I also want subsequent chapters evenly spaced after that without having them on the menu.
    1) Can it be done?
    2) Can it be done with TMPGEnc DVD Author?
  2. Yup, and yup. What you want to do is go into "Edit Menu", then "Display menu settings", then "chapter display", and then you remove the check from however many chapters you want. Remove the check and it will not appear on the chapter selection screens.
  3. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    yea...what Matt D said.
    Nov 2004
    Perfect! Thanks!
