i thought i remembered seeing somewhere here that this would happen....
i converted a 1 hr xvid mpeg4 at 1 pass from 23.976 to 29.97...also 608x336 to 720x480....everything looks good upon a quick check except that my 350 MB file is now 2.4 GB...
is there anyway to keep the file down to around 1 GB or so?...or can i shrink it with dvdshrink wihout losing much quality?...i was hoping to get 4 hrs on a dvd...
looter
...is at least twice too much if you're concerned about quality.Originally Posted by zootedlooter
/Mats -
If you add 4 hours then the bitrate will be lowered to ensure that they all fit on the DVD... BUT as Mats states, the quality will suffer greatly. That said - give it a try.
worked for me.....quality was fine on my 51".....great job on the 2.0 CB....i used to spend hours converting before now....
looter -
Nice one!
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
TP to AVI conversion
By nic3 in forum Video ConversionReplies: 0Last Post: 20th Nov 2009, 18:04 -
DVDRebuilder/HC Encoder making oversized file
By ricoman in forum Authoring (DVD)Replies: 8Last Post: 2nd Aug 2009, 16:10 -
DVD Video Image Oversized Question
By JerryRecords in forum Video ConversionReplies: 3Last Post: 21st Dec 2008, 12:14 -
Oversized video file...
By Felo in forum Video ConversionReplies: 3Last Post: 18th Jan 2008, 03:14
