  1. hi i am looking for a dvd authoring program between a simple one like sonic, and an advanced one like adobe encore. i tried dvd-lab, and that was perfect, except i need it to be able to burn .avi files. any suggestions? thanks
    Jan 2002
    Not the end of the world!
    You cannot author avi files and burn them to dvd. All authoring programs for dvd require mpeg2 dvd-compliant files.
  3. Member GeorgeW's Avatar
    Feb 2005
    @spol, do you mean your source videos are .avi, and you need an Encoder to make them DVD Compliant?
    If so, you could go with DVD LabpPro, and add in their DVD Source Creator option for $29.00
    http://www.mediachance.com/dvdlab/dvdsc.html
    Or go with an encoder of your choice:
    -Canopus Procoder
    -Mainconcept Mpeg Standalone
    Or get an Authoring Package that has a builtin Encoder with some advanced Authoring tools like subtitles, playlists, multiple audio tracks -- Ulead's DVD Workshop 2.0 Express might fit that description...
    George
