Closed Thread
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello everyone, i have this set of RAR files, and im pretty sure it is like u unrar one and it collaborates with the other files to extract the whole thing.
    when i try to extract the highlited file, i get this error:
    does any one know how to get rid of this error?
    Wow! You got shocks, pegs... LUCKY!
  2. Try
    File/select all/ then extract....
    I dont think it will work but its worth a try. Sounds like its a croupt file and you need to download again......
    Not bothered by small problems...
    Spend a night alone with a mosquito
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    nope it doesnt work...thanks for posting so quik BTW.
  4. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    like the error message says, the files (one or more rars) are corrupt.
    try opening the torrent again and see if it will fix it.
    by the way, thats warez and you're probably going to get a warning for it.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    buy the game.
