hi
i want to buy more ram for my PC, but i keep comming across two different types. EEC(non conforming, and EEC (conforming i guess). i was wondering what is the difference? i want to make sure i get the right one. is one better than the other?
any info(or link) would greatly help.
thanks![]()
Long answer:
http://bugclub.org/eric/memory/index.html
This site details the various RAM types, interesting and very useful; slightly out of date but close enough.
Short answer:
A quick check of your motherboard specs and I see the manufacturer notes:
Max. 2GB DDR
2 x DDR slots , DDR333/266/200
So search for "DDR 333 RAM" on the web (might as well go for the fastest!) and the max your system can hold is 2 1gb DDR memory modules. As for ecc or non-ecc, don't sweat it -- 99.9% of what you find will be non-ecc anyway, which is fine (I've only ever seen ecc ram used in servers or a couple of systems with big warning stickers on the motherboard that say ECC RAM ONLY!)
Replacing DDR slot on mobo ???
By blinky88 in forum ComputerReplies: 4Last Post: 12th Jul 2009, 13:57 -
DDR and DDR2
By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 07:50 -
DDR vs DDR2
By CSULB71 in forum ComputerReplies: 2Last Post: 1st Jun 2008, 14:54 -
DDR versue DDR2 Question
By SCDVD in forum ComputerReplies: 8Last Post: 11th Oct 2007, 13:50 -
Question about refreshing DDR RAM for video application.
By SingSing in forum Video ConversionReplies: 7Last Post: 13th Aug 2007, 11:41
