I know I can set up a slideshow of jpgs from a DVD but what if I want to display a page of text? Do I have to convert text to jpg?
What are you using to make the slideshow?
Cheers, Jim
My DVDLab Guides -
Nothing yet. I have two or three pages of text I'd like to add and link to from the main menu.
Doh!!! I could just format and add the text to a menu - that would actually be the easiest and that way the user could go back to the main menu whenever they're done reading.
Thanks's for listening!
P.S. Using TMPGEnc DVD Auth -
Looks like TMPGEnc DVD Author won't let me add text if its not the Menu title or Chapter label. Is there a way to add text to a menu in the Theme Edit Mode?
He's a liar and a murderer, and I say that with all due respect.
Screencap the text with a free utility like HyperSnap DX4. Or you could use something like DVD Menu Studio or PhotoShop Elements to generate the text in a 720 x 480 frame. Resize to 720 x 480 and convert the uncompressed TIF into JPG with PhotoShop or Corel Draw or MS Paint or GIMP 2.0. Then Use AViSynth or VirtualDubMod or Ulead MediaStudio Pro or Adobe Premiere or Vegas Video to convert a series of jpg files into a slideshow. How long each screen of text lasts is determined by how many times you tell the program to copy it -- at 30 frames/sec, you get 1 sec if you paint the jog onscreen for 30 successive frames.
fuzzy text/desktop display with Sony Bravia TV
By Bacillus98 in forum Media Center PC / MediaCentersReplies: 12Last Post: 24th Feb 2016, 12:29 -
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
How to get rid of this text display ?
By wapw in forum Software PlayingReplies: 4Last Post: 11th Jul 2008, 14:44 -
Add Text to DVD & CD To Display On Player
By drtalk in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2008, 13:35 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
