Hi
I hope someone will help me..
i got a xvid/avi file with AC3 audio ( 2 channels). The audio is completely sync and it's perfect
I demux .ac3 and then i clicked disable. After this, i save as avi.
And then i encode the avi file using tmpgenc plus to DVD format (m2v)
Finally i used tmpgenc dvd author. I added m2v as video and .ac3 as audio file. And then i encoded.
BUt the resulting is the audio out of sync...not much..it's only a few miliseconds.
How to fix this? can someone please help me? my english is not good so forgive me
thks
Results 1 to 14 of 14
Use ac3fix to fix ac3 file before remuxing. It's a dos program.
Nothing is impossible for DiLeMmA says so!
See my guide on how to batch author dvds!
https://www.videohelp.com/forum/viewtopic.php?t=255213 -
hi
thks for the reply
yeah i did use BeSlicedv0.2 to fix the ac3 before putting it in tmpgenc dvd author,....i couldnt add the ac3 file at first..it said illegal audio format so i used BeSlicedv0.2 to fix it.....BUT still the same problem! (crying) -
Ok.......this is what you need to do.......By the way....use ac3fix on the ORIGINAL ac3 file.
You need to place a copy of ac3fix.exe in the same directory of the ac3 file. Then you need to open a dos prompt.....START---->PROGRAMS------>Accesories----->Command Prompt if using XP. Navigate to where the ac3 file and ac3fix.exe is located using the command prompt (cd c:\your directory). Then type ac3fix.exe 1.ac3 new1.ac3.
1.ac3 being the name of your ORIGINAL ac3 file and new1.ac3 being the name of the new fixed ac3 file.
Let me know how you did
Hi
how to preview whether it will sync or not?
is there any software for me for testing?
i tried virtualdubmod to preview it but it seems lagging -
No, you just have to reauthor with the new file.
with ac3 delaycut can you a few milliseconds cut or place silence before
http://jsoto.posunplugged.com/audiotools.htm
this way is only when the audio out of sync is the whole movie and the same time -
hi dillema
yeah...it said no bad frame encountered and it created a new file for me. I did what u guided me.
Am i doing correctly?
thks
and thks tarzan1990, i wil try that method out but i scare i cant handle it cause i quite stupid when comes to audio sync. -
The audio comes a litle seconds before the video whole the movie,
then you must import the audio (1) in delaycut
By delay you fill number of audio out of sync in ms.
Click on process.
Now the result is an ac3 file with the name fixed.
The video comes a little seconds before the audio whole the movie,
then you take the option of cutting
Now an another way is cuttermaran
you can cut the m2v of ac3 only
hi tarzan1990
i will try this out and i will let u know whether succeed
Is there any way can preview so that i can know whether it's sync or not?
thks a lot for all of ur helps...really really appreciate it
Going mad trying to demux a TS
By twinaleblood in forum Video ConversionReplies: 16Last Post: 22nd Jul 2012, 13:54 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
WMV encoding driving me mad
By cutitfine in forum Capturing and VCRReplies: 2Last Post: 27th Dec 2007, 22:39 -
AVI to MP4 Audio out of synch!! HELP!! DRIVING ME MAD!!!
By traqman in forum DVD RippingReplies: 7Last Post: 15th Jul 2007, 01:01
