Can you cut a clip inVdub before you compress it? Does that have any effect on quality? Or should you encode whole clip then cut it afterwards? I know when you demux or mux tracks you shouldn't cut the video.
If you frameserve to your encoder, you can cut whatever you want in vdub...otherwise yes, there can be quality loss, unless you save it uncompressed.
Cheers, Jim
My DVDLab Guides -
When you have the option, cutting SHOULD be done before encoding to preserve quality. In most cases you can also cut an already encoded video, but there will be degradation if any of the cuts need to be re-encoded, though it may not be noticable.
Buy My Books -
A couple of times I have had the sound slip out of sync slightly when I have cut out sections in VirtualDub and then frameserved to Mainconcept MPEG Encoder. Couldn't work out why it happened. So I usually encode the whole thing and then cut out parts with Womble MPEG VCR. I would recommend you run a few tests.
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29 -
Editing .wmv in Vdub
By imdaman in forum EditingReplies: 9Last Post: 9th Jan 2010, 17:09 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06 -
editing movies in vdub: how to get whole vid in memory?
By SignedupGuest in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2008, 09:14 -
Vob / Mpeg2 editing with Vdub
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2008, 18:55
