I'm experimenting with DVB MPEG2 downloaded movies. I want to convert and burn to a DVD, but am having some trouble getting good audio and video quality, so I'm using a number of programs and methods. To save wasting DVD-R disks I bought a few TDK DVD-RW disks so I can burn and see how it worked and try another without wasting media. My question is do I have to format the DVD-RW first before burning a movie to it or do I treat it as a regular DVD-R and just burn?? And once the movie is burned and I want to start over and try again do I just erase, format, or delete the file?? Thanks!!
Also should the quality of the record be as good on a DVD-RW as opposed to a DVD-R??
Yes.Originally Posted by bcsman
Yes, quick erase will do too.Originally Posted by bcsman
In strict terms yes, it is digital so the quality of the movie will stay the same irrespective of the disk type. However RW's seem to cause more problems with players than record once media, so there is chance you may get stuttering, skips and jumps with RW that you don't get with R media, it depends on your player and the media used.Originally Posted by bcsmanThere are 10 kinds of people in this world. Those that understand binary... -
I apologize, I guess my question was asked incorrectly. Unless I format the DVD-RW first before I burn a movie to it, will it be erasable?? I'm afraid if I just place the unformatted DVD-RW in my BENQ and burn I won't be able to erase when I want to try another movie?? Sorry about the confusion on my part!!
hi bcsman,
Just load in the DVD-RW disc like any DVD-R. If you have already use the DVD-RW before (i.e. have data in the DVD-RW) your burning software will prompt you if you want to overwrite your old data. I use NERO and I guess all burning software works the same.
EDIT : There is NO need to format the DVD-RW if you want to burn movies. If for data, then you need to format.
P.S. Be careful with -R and -RW media on Benq DVD burner. It can be picky.
New to DVD movie burning - Help?
By dvdburning in forum Newbie / General discussionsReplies: 3Last Post: 11th Jan 2010, 00:51 -
Burning a movie to DVD
By johnnyo34 in forum Authoring (DVD)Replies: 6Last Post: 6th Jan 2010, 19:04 -
Burning DVD movie into CD R
By c1steady in forum Newbie / General discussionsReplies: 17Last Post: 8th May 2008, 15:17 -
burning 2 parts of movie to 1 DVD
By popgun2k in forum DVD RippingReplies: 2Last Post: 27th Jun 2007, 10:07 -
Burning edited DV movie to DVD
By roster19 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st May 2007, 01:40
