Looking for some general help in regards to converting files for playback on the GM minivan PhatNoise system.
I've used FairUse Wizard to covert files over to DivX (should I use XVid instead?), and the resulting files do not fill the entire 7" screen in the vehicle.
PhatNoise notified me that the screen supports 740 x 420 (16/9) (I think this is right, don't have the manual in front of me, but it's close). Anything smaller will result in the image smaller than the screen, anything larger will not play!
When using FairUse should I:
(a) crop the video to only capture the actual movie image?
(b) select the largest "preferred resolution" for the output video? This never seems to get too the 740 pixel width of the screen, but close.
(c) what about the anamorphic check box? when do I check that? Based on the original movie aspect ratio I guess, but what?
(d) HD resolutions? Should I check that for more options, but stick with "prefered" options too?
Thanks! Need to get this clear for all the "soccer moms" who will soon be on the boards with these same questions!![]()
Results 1 to 1 of 1
Divx Aspect Ratio Change??
By gdb in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2011, 07:34 -
How do I create a DIVX w/correct aspect ratio
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Oct 2008, 10:16 -
VDub/Divx - How to setup Aspect Ratio
By neomaine in forum Video ConversionReplies: 7Last Post: 6th Feb 2008, 17:05 -
TV Episode in DIVX different aspect ratio from original broadcast
By gromit60 in forum Newbie / General discussionsReplies: 5Last Post: 6th Jul 2007, 03:34 -
Changing an aspect ratio on DIVX
By diablo_jones999 in forum Video ConversionReplies: 13Last Post: 29th May 2007, 12:53
