  1. I recently had to reload Windows xp and now that I've finally loaded back everything I'm getting messages to say that it can't find a codec for my mpeg file. Can anyone point me to a good codec package or something?! Thanx.
    Cheers and Be Lucky
    free mpeg2 codecs:
    GPL MPEG-1/2 Decoder
    Stinkys MPEG2 Codec
    Dscaler MPEG Filters
    Or just install PowerDVD or WinDVD or some other dvd software player and you should be able to play mpeg2 with most players.
  3. Member kb1985's Avatar
    Sep 2004
    Poland
    I had similar problem on windows 98. It was the problem with the registry i had to fix it byretrieving last copy.
  4. Mod Neophyte redwudz's Avatar
    USA
    What Baldrick said.
    XP doesn't come with a MPEG-2 codec. Copyrights or something.
    You can install one of the players and uninstall it and the codec should remain if you don't want the player. Or use one of the free codecs.
  5. Thanx guyz. I'm working on it,but my monitor has just decided to pack up (borrowed my daughters for now) so that is taking up my spare time at the moment!
    Cheers and Be Lucky
