  1. Video Restorer lordsmurf's Avatar
    Where is the "analysis results file" so I can delete it?
    My problem is I have ripped a DVD to the hard drive, and ran shrink on it, but I have forgotten to remove the extras and unneeded languages. I remove these things, and re-shrink, but the quality looks the same, even though the % changed drastically. We're talking 90-95% here total shrink, yet the disc has not changed in quality.
    I believe it is this stupid little results file causing the problem.
    It used to be referenced here: http://www.chrismccann.co.uk
    but that site is now offline.
    Version 3.14 "Fixed bug where analysis results file could be saved to the wrong filename after "deep analysis before backup", so the results were not cached when opening the same DVD a second time."
    ... I'd like to have this bug.
    Version 3.1 beta 5 supposed "Added Close All Open DVDs menu option which flushes and resets DVD Shrink cache of opened DVDs."
    ... but that doesn't work.
    Installing DVD Shrink v3.12 is still showing that analysis was already done.
    Any ideas?
  2. Reboot ??
    The electronic components of the power part adopted a lot of Rubycons.
  3. Member bidefordboy's Avatar
    Nov 2004
    Treasure Island
    If your harddrive is C :=
    C/documents & settings/all users/application data/dvd shrink
  4. I may be on the wrong problem here but I seem to remember some time back a simular post where you have to set explorer to show hidden files to enable you to view then delete them.
  5. The files may also be in the "All Users" folder and not just one user name. The easiest way to find them is to search for "analysis results" on the HD and they will pop right up.
