Hi all
[UPDATE]
nm, i found the answer, http://excamera.com/articles/24/movie.html
if anyone else wants to fix the audio for 3gp decoding
i need to encode 3gp files to mp4 and wmv, but i get an error from audio input
when i run ffmpeg -formats 3gp and 3gp2 only come up with E, does this
mean i cannot use them for input stream
it works with audio disabled, can anyone tell me what i need to do (if i
can do anything) to get audio into the output files?
the audio input stream seems to just be a hex number rather than a codec
DEV D h261
DEVSDT h263
D VSD h263i
EV h263p
D V DT h264
DE h261 raw h261
DE h263 raw h263
DE h264 raw H264 video format
E 3g2 3gp2 format
E 3gp 3gp format
the above is from -formats
[root at devserver videos]# ffmpeg -i /temp/alienspredator.3gp -b 100 -ar
22050 -ac 2 -vcodec mpeg4 /final/ap.mp4 -vcodec wmv1 -acodec mp3
final/ap.wmv
ffmpeg version 0.4.9-pre1, build 4752, Copyright (c) 2000-2004 Fabrice
Bellard
configuration: --enable-faad --enable-gpl --enable-faac
--enable-faadbin --enable-mp3lame --enable-shared
built on Apr 26 2005 13:57:33, gcc: 3.2.2 20030222 (Red Hat Linux 3.2.2-5)
Input #0, mov,mp4,m4a,3gp,3g2, from '/temp/alienspredator.3gp':
Duration: 00:00:37.0, start: 0.000000, bitrate: 71 kb/s
Stream #0.0: Video: h263, 176x144, 12.00 fps
Stream #0.1: Audio: 0x726d6173, 8000 Hz, mono
Output #0, mp4, to '/final/ap.mp4':
Stream #0.0: Video: mpeg4, 176x144, 12.00 fps, q=2-31, 100 kb/s
Stream #0.1: Audio: aac, 22050 Hz, stereo, 64 kb/s
Output #1, asf, to '/final/ap.wmv':
Stream #1.0: Video: wmv1, 176x144, 12.00 fps, q=2-31, 100 kb/s
Stream #1.1: Audio: mp3, 22050 Hz, stereo, 64 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Stream #0.0 -> #1.0
Stream #0.1 -> #1.1
Unsupported codec (id=73728) for input stream #0.1
thanks
dave
I am having troubles that looks like this one, except for the sound can be listened on pc but not on dvd-player. I have set the sound to 500% and nothing and making an iso first. What Its happening?
Can't Mux audio & video streams to MP4 without a problem
By spycam in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2010, 16:49 -
How to Combine MP4 Clips and then to WMV & AVI
By gonwk in forum Video ConversionReplies: 3Last Post: 2nd Mar 2010, 08:35 -
JPEG Digital Camera & MP4 & FLV
By Russo in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2009, 15:03 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 07:02
