I'm converting 6-chan AC3 to 2-chan MP3 using BeSweet. I find the dialog a bit hard to make out in the original AC3...in other words, I think the surround effects are overpowering the speech.
How can I boost the speech only?
I would like to set the AZID parameters to optimize speech.
Here is the AZID part of my BeSweet Log:
[00:00:00:032] | Input Channels Mode: 3/2, Bitrate: 448kbps
[00:00:00:032] | Output Stereo mode: Dolby surround compatible
[00:00:00:032] | Total Gain: 10.000dB, Compression: Normal
[00:00:00:032] | LFE levels: To LR -3.0dB, To LFE 0.0dB
[00:00:00:032] | Center mix level: BSI
[00:00:00:032] | Surround mix level: BSI
[00:00:00:032] | Dialog normalization: -4dB
[00:00:00:032] | Rear channels filtering: No
[00:00:00:032] | Source Sample-Rate: 48.0KHz
If I changed Dialog normalization to -2dB, would that help? Would any of the other settings be helpful to change?
Sound Forge --> Speech Over Background Music
By Omnipulator in forum AudioReplies: 0Last Post: 20th May 2009, 23:00 -
Delaycut question about 6 chan ac3 out of sync when 2 chan is in sync
By B2K24 in forum AudioReplies: 3Last Post: 27th Apr 2009, 16:10 -
Converting WAV to AC3 - sound loss
By MackemX in forum AudioReplies: 10Last Post: 19th Mar 2009, 15:15 -
DVD on computer, no speech, How to downmix AC3 5.1?
By Perro in forum AudioReplies: 4Last Post: 8th Mar 2009, 03:29 -
Advice Req: Filtering Audio Files For A Clearer Sound
By Teac23 in forum AudioReplies: 2Last Post: 27th Nov 2008, 09:43
