i am trying goto vcd/svcd to dvd i am not having any luck i tryed to used vcdgear Bin/Cue -> mpg & , once i get it to mpg i can not put it into anything i tryed to put it TMPGEnc /TMPGEnc 3.0 XPress/TMPGEnc DVD Source Creator/VirtualDub
can ne1 give me any suggustions plz
now i tryed to put avi to dvd i cant get a full dvd ,i tryed to dvdsantawhen i used it i got about half the dvd .then i tryed tdo used winavi it made it in to a dvd folder it was 7Gigs and i cant shrink it i cant use dvdsanta
to get 4.35+ Gigs i need help please
i tryed looking around the site for help and all of it did not work or i cant figure it out or when i follow the inst. i get so for and i get an error any sugestions.
SVCD's standard resolution is 480x480 which NOT compatible with DVD. You need to re-encode the 480x480 to 352x480 or 720x480 for it be DVD compatible. Most authoring programs will reject 480x480. VCD is 352x240 which is DVD compatible unless your VCD is in different resolution.
foravitodvdishouldgoreadsomeguidesonthesubjectunde rconvertforsvcdiagreewithabondvcdcan beauthoredwithtmpgencdvdauthorastheyare
Poor guy may need a guide or decoder for this !!Originally Posted by mats.hogberg
When I was born I was so shocked that I could'nt speak for 18 months. -
some dvd players will playback non-standard content, although there are no guarantees. DVD Lab will allow you to import SVCD content, transcode the audio to be compliant, then burn it to dvd. some players will refuse outright, others will play with distortion of the image, and others wont batter an eyelid as they put it up on the screen. yes, it is non-standard and non-compliant, but is can be done pretty easily.
Read my blog here.
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 21:42 -
Converting .mov or .avi to flv does not work
By Alainb2809 in forum ffmpegX general discussionReplies: 22Last Post: 11th Oct 2010, 14:33 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 08:05 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 05:30 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 23:13
