  1. I havbe a perfectly good .avi movie. Is there a way to resize it or crop it and leave the audio and video the way it is? I have put it in Virtual Dub and left the audio and video the same and tried to crop out the movie but it does not work unless I am doing it wrong.
  2. To trim in VirtualDub:
    File -> Open Video File
    Video -> Direct Stream Copy
    Audio -> Direct Stream Copy
    Move the frame slider to the starting point, press the Mark In button.
    Move the frame slider to the ending point, press the Mark Out button.
    File -> Save as AVI
    Note that Direct Stream Copy mode can only cut on key frames. You can locate key frames by holding down a shift key while moving the slider or pressing left/right arrow keys. You can also see a little [K] next to the frame number.
  3. I don't want to shorten the movie, I want to resize it and take out the big blaack border around it.
    Feb 2005
    Try this post...I had the same problem a while ago https://www.videohelp.com/forum/viewtopic.php?t=259671&highlight=
    Try using the avi resize calc that gunslinger links to in his profile. It helps alot.
    Check out the Band...feel free to PM me with opinions: http://www.purevolume.com/beneathitall
  5. Originally Posted by ssandhouse
    So you have a AVI that looks like this:
    And you want to remove the black borders to make it look like this:
    Or do you want to watch it on a 4:3 TV and look like this:
    VirtualDub can do any of this. Of course, any time you crop you will have to reencode.
