hello people
I have 11 files, avi's, mpeg's and wmv's of total size 4,511MB and the dvd free space is 4,489MB
can you tell me please if there is a way to fit the files in the dvd?
thank you very much
Results 1 to 10 of 10
you must either cut or reconvert a video. you can't overburn on dvd.
Plextor is an exception to the DVD overburning rule, if by some chance you have a Plextor burner. I don't know of any other drives that do overburning, but a Plextor would be able to fit 4511mb.
But I wouldn't trust it to be readable on anything else.... but a Plextor would be able to fit 4511mb.
Buy My Books -
;Originally Posted by gadgetguy
I suppose there'd be drives that might have trouble with the discs, but over at Cdfreaks people have been overburning +R discs to 4600+mb and they read back on other drives fine. This isn't the same as weird GigaRec or similar oddball ideas, I believe the Plextor simply writes into the Lead-out area, where some discs would probably handle more additional data than others before reaching their limits. -
That's the best advice yet :POriginally Posted by Stormin Norman
Normally you can't compress video hardly at all, but since he only needs about 25mb out of about 4500mb of additional space, it might be able to be compressed just enough to fit. -
thank you
can you suggest me a tool to cut the last part of an avi, mpeg, wmv file?
can you tell me how to compress and what to compress?
(I dont think I will go for zipping couse I want them to play instantly and to play in a stand alone dvd player) -
That little sentence changes everything.Originally Posted by ecos
First, add the running length of all 11 files together. Use this time in a bitrate calculator. You'll get a bitrate to use when encoding to DVD specs. With this bitrate, encode each file to DVD specs mpeg. How and with what to do that, depends on the source file format. See the convert section for ??? to DVD suggestions.
Finally author all 11 mpg to Video DVD using some kind of authoring app like TMPGEnc DVD Author.
/Mats
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
DL+ burn fails with ISO file larger than 7 Gig. Why?
By anubis13 in forum DVD RippingReplies: 5Last Post: 5th Dec 2009, 19:48 -
Larger File Type
By AudioSync in forum Newbie / General discussionsReplies: 3Last Post: 18th Mar 2008, 12:20 -
Auto-fit seemingly creating larger DVD's
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 16th Oct 2007, 17:08 -
larger file size from .avi to h264
By sai351 in forum Video ConversionReplies: 3Last Post: 4th Jun 2007, 14:20
