  1. Hi,
    Is it possible to set AIW guide plus to change the channel only and capture with Virtualdub? Is there any other way to change the channel automatically for example for channels without any guide plus information like Discovery, etc.
    I have an ATI All in Wonder Pro 128, Duron 900 and am running windows 2000
  2. There isn't any way that I have found. What is it that you want to do precisely? Do you want to record one show on one channel at one point and then another channel at another point without being there? You might try FreeVCR for that. Other than that I know of no way to automatically change the channel with AIW and VD.
    Macros
  3. Exactly, I don't get all the channels in the guide plus software here in Quebec, Canada and I'd like to be able to record on different channels while I am not there. I don't mind wether this is done with guide plus, some other software or even with command line. In fact I would prefre command line, I could write some software to program my computer with a web interface, that would be really cool.
  4. I have found the wonder that is AVI_IO and you should try that. It is essentially a sawed off version of Virtual Dub but the timing feature is much more advanced. Give this a spin.....
    Macros
