    Mar 2005
    Usually I have Play Movie and Chapter Selection right below it, when i switch between the two it becomes highlighted (whichever one im on is highlighted) instead of that how can I have a arrow or ball or something else on the side to indicate what your remote is on and what you are about to push.
    On the main menu I usually have a song playing but is there a way to have 2 or 3 songs playing one after another in the same Main menu, not talking about a different song per chapter selection menus. Also would it be possible with dlp to add a little play-stop-next song, kind of icon on the main menu to give me the ability to skip or stop a song.
    thnx guys
    Apr 2004
    Miskatonic U
    A1 : Don't link to the text, just create a symbol (DLP has some, or create one in photoshop and import), place it next to the text, and link to it instead.
    A2 : Look up playlists in the help files. You can create title playlists or chapter playlists depending on how you have you assets prepared. Depending on how complex you make your playlists, you can get any order happening. That might address your 'play next song' question as well, although I'm not entirely sure I understand it.
    Read my blog here.
  3. You need to use switched menus to create the hilighted arrow effect. Easy to do, using the built in wizard.
    To have switchable audio, you need to generate an identical menu for each audio track, then just make a link button as any other. That way, you can switch audio, but the menu appears the same.
    Cheers, Jim
    My DVDLab Guides
