I'm making a video that will be nothing more than a high quality Quicktime file upon completion. [No MPEG2s for DVDs or anything.]
So. Once and for all... how do I get rid of the crappy interlacing lines that rear their ugly head in scenes with any kind of moderate movement?
The de-interlace filter within FCP doesn't do much of anything for QT output, it seems.
What to do?
Dandy little application, but is there any way to avoid massive file size increases without shrinking down the size of the video?
For what purpose? After all, you are effectively doubling the video information of your movie. If you plan on continuing to edit then I would say keep it in your de-interlaced DV. If you are creating a final output then consider a 3ivX single pass at high quality, or DivX or any MPEG-4 based codec.
FCP question
By jlowell in forum MacReplies: 2Last Post: 31st May 2010, 21:18 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 20:50 -
Distortion in FCP
By Daniel Corcoran in forum MacReplies: 7Last Post: 27th Jun 2008, 15:58 -
NO Audio in FCP ???
By willndmb in forum MacReplies: 3Last Post: 22nd May 2007, 13:33
