  1. Im trying to author a DVD and there used to be a guide that showed you how to "cheat". You would convert the audio to 48 khz and add a header to the video and stuff so that it wouldnt need to be converted in Ulead MovieFactory. Anyone have a clue of what Im talking about?
  2. Member GeorgeW's Avatar
    Feb 2005
    DVD MovieFactory 4.0 (just released) allows for using "out of spec" mpeg files (to a certain degree). For instance, it will allow you to ue SVCD mpeg-2's for a DVD Project (without needing to modify the header). It will still convert the audio to 48khz, but at least you don't have to convert the video.
    George
  3. Well, does it fix the out of sync problem 3.0 has? Thats the problem I have.
  4. Thanks, the first is what I was looking for.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    guides section << to your left
    If in doubt, Google it.
