i put five hours of video in 720x480 resolution onto one duallayer disk and still had around 1500mb of space left!!
orginal file size was a little over 10.000mb but was shrunk with dvd shrink using the fastest possible way with no special options enabled it was a direct encode!!
here is a clip of the compressed video.
here is another is anyone else impressed buy how much video these things can hold in excellent video qualuty??
Originally Posted by kenmasters83If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
shocker you want to hear something funny??
upon mentioning memore three pack dual layer dvd's at buy.com they sold out the next day..
somebody's buying them...all of them -
I tried a 3 pack of Verbatims myself, but I won't be buying anymore until the price hits $2 per disc.
George Carlin -
well i have hit the limit upon testing the maxium capacity dual layer media it can hold 6 hours of video at 720x480 if you run deep analysis on the video with dvd shrink..
i havent tried any of the AEC options but i am pretty sure it would look just the same its time consuming it takes nearly an hour to do that..thats why it wasnt included in my tests..
i say its the limit because i have been testing it out for the past few days if others wanna join in on the testing please dont hesitate to do so..
to do the test's you need dvdshrink and tmpgenc dvd author and some previous recordings or captures the file size limit is 8 gigs and do you do NOT need a dual layer burner to do the tests just watch the outputted videots folders by dvdshrink for compression artifacts and the like..
the more i test the limits of this media the better the results are getting. -
You're not really testing the media, now, are you ?
Surely you're doing a comparitive test between a transcoder and re-encoding - both are probably pointless with dual layer discs anyway. It doesn't matter how good the discs are if you've shot the video data to buggery by over compressing it. -
Originally Posted by Shocker Milwaukee
I'm not even buying a DL burner until the price of media hits $2
not to mention until I can actually find the DL media"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
DVD Players That Handle The Layer ...Break Well.
By Goblin~Magnet in forum DVD & Blu-ray PlayersReplies: 8Last Post: 1st Jul 2010, 08:43 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
