Can someone clear up some questions I have about MiniDV? First off, MiniDV is it's own format. It has PCM sound and it's own video codec and rate. This is my understanding of it.
Why are some MiniDV cameras MPEG-4? Do they simply record in MPEG-4 with PCM sound on a MiniDV tape or just a memory card?
Why can't I find any exact details on this?
Tom Green Sucks!
IIRC, all the "MPEG4" capabilities touted by the various digicam makers are really only when captured in very small clip segments and stored on the available smart card.
There are only 2 standard formats that actually record information onto the DV tape--DV (and sister formats of DVCam, DVCPro) and the new HDV. And since HDV records an MPEG2 Transport stream, there really isn't any MPEG4 signal that gets recorded onto a DV tape.
BTW, there are 2 sizes of the DV tape shell that are in use, depending on what camera & VCR you are using (and how much time you need to put on there):
1. Small shell, or "miniDV" (most common)
2. Standard (larger) shell (seen only on pro decks)
Either way, it's still the same signal.
Also, it IS possible to use a PC and special software to masquerade another file/format/signal as a DV-type video signal, and so transfer it to and from a camera (via 1394 cable), often for purposes of data backup. But there is no such thing as a recording function like this in a standalone camera.
Scott -
Are you referring to solid state cameras that record to ram (slightly different to DV cameras that record to memory cards). Some less reputable ones have tried to usurp the DV name as generic Digital Video. If it doesn't record to miniDV tape, it isn't miniDV
Read my blog here.
MiniDV capture too dark!
By johnb41 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 7th Feb 2010, 13:21 -
Fast-forward MiniDV during capture?
By occams_r in forum Capturing and VCRReplies: 3Last Post: 27th Dec 2009, 16:37 -
JVC miniDV video capture on a pc ?
By silverclaws in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2009, 07:55 -
MiniDv Capture Advice
By afoote@acslink.net.a in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Nov 2008, 07:22 -
HELP- MiniDV capture TOO DARK
By cheeverm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 27th Jun 2007, 14:03
