I can capture a home video (VHS) to the PC in either AVI or MPEG2 format. The film is quite dark and I would like to use an editor that will let me use Colour/Brightness/Contrast etc. to edit it before I burn it to a DVD.
Any suggestions to such program please? I would prefer to edit the MPEG2 if possible.
You can use TMPGEnc Express or the standard TMPGEnc to adjust the color/contrast/brightness then reencode.
I capture VHS using WINDVD Creator 2 with the Plextor ConvertX and that allows you to adjust the colors/contrast/brightness when you capture. There are probably better apps out there but this one came with the ConvertX. -
Before you edit the film have you tried watching it on your dvd with a dvdrw?Watching on a computer monitor will give you much darker pictures than a tv screen at times.
Captured video but what to do since file is huge.
By I26 in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2010, 20:19 -
how do I tell what date a dv file is from captured with windv?
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 16th Dec 2009, 08:04 -
Editing audio track from 1080i TS captured from DVR
By pulsation in forum AudioReplies: 3Last Post: 27th Oct 2007, 21:34 -
Shortening a Captured File
By solarblast in forum EditingReplies: 8Last Post: 21st Jul 2007, 13:19 -
Captured File Size Question
By pbmc59 in forum Capturing and VCRReplies: 10Last Post: 6th May 2007, 21:41
