  1. Hi.Can anyone tell me why my new Philips DVDR610 keeps suddenly going to switch itself on for no reason, but doesn`t quite, & causes the TV screen to go black for a second or two & then goes back to channel we are watching.When it does this the front panel on the recorder goes blank for that second or two aswell.Please can someone help as it is driving us all mad.
    Thanks,Dave
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Although I have had great luck with my Philips recorder....they are known to be a pain in the ass when it comes to reliability.
    Jul 2005
    Europe
    Hi Dave, I have weird things like what you described happening with my own Philips 610. Now and then, it stops recording. Then it would go on again, erasing what it recorded one minute before. This drives me mad too. I will have it checked soon. Did you find a solution for your problem? I checked the Philips website in search of some useful support but found nothing helping.
  4. HI SYLVIE.
    YES I CONTACTED PHILIPS DIRECTLY & THEY SAID THAT THIS PROBLEM IS RECTIFIED BY AN UPDATE AVAILABLE ON THEIR WEBSITE.I SAID THAT I WOULD RATHER HAVE A CD OF THE UPDATE & THEY SENT ME ONE WITH FULL INSTRUCTIONS.I INSTALLED IT & IT HAS CURED MY PROBLEM APART FROM OCCASIONALLY I TURN UP THE VOLUME WITH MY SAMSUNG TV REMOTE & THE DVD RECORDER SWITCHES ON,NOT EVERY TIME JUST VERY OCCASIONALLY.
    HOPE THAT HELPS YOU.
    DAVE.
    Jul 2005
    Europe
    Oh yes, it does help me, thanks a lot!
    On the Philips site they speak of a download that would fix the problems but I couldn't find out where the so-called download was...?
    Have you called them to have the CD? Or did you send them an email?
  6. HI SYLVIE.
    I EMAILED THEM.THE UPGRADE NUMBER ON MY DISC IS BT1_26 . HOPE THAT HELPS.THE CUSTOMER PHONE NUMBER FOR PHILIPS IS 09061-010016,THEN PRESS KEYPAD NO.8,ALTHOUGH I AM IN ENGLAND SO IT MAY BE DIFFERENT FOR YOU.
    DAVE.
    Jul 2005
    Europe
    Hi Dave, thanks for your answer. I went back to the Philips site again and eventually downloaded an update in English, I don't know if it's the good one for my writer, as the writer is supposed to speak French like me
    Plus the files I downloaded seem to be PC files and I have a Mac so I am not sure I can burn them on a CD that will be correctly readable by the DVD writer, and don't want to harm it trying to install the wrong update.
    So... I will email them like you did, and see what they have to answer.
    Thanks a lot for your help!
