Hi,
Well I don't now what is better, my problem if that I don't now what buy.
I can buy 3 diferent products, for 2 configurations.
1. Buy a Home theater Samsung HT-DS420 that have a DVD player with DTS and Dolby Digital decoder with speakers.
or
2. Buy a AVR Sony HTDDW660 + dvd player Pioneer DV-373-S.
Yes, maybe not are the best systems but I only have money for buy this products.
Either one of those look OK. It looks like the Samsung player will play DivX.
Google is your Friend -
My preference would be for the seperate components. Why ? Because the player is likely to die before the amp. You can replace it cheaply, or plug in a second player or DVB box etc. Buy an all-in-one and the player dies, you have nothing left.
Both look OK for the money, but seperate components give you more freedom and better reliability.Read my blog here.
Seperate components are my choice also, but the in low cost market, either of those would suffice. Besides, if the player dies, you could just get another DVD player and feed it into the existing amp.
i have had both configrations in my course of time. i would prefer a dvd player + AVR because they have more power and you have more control over how you want to set up and they are better decoder than the all - in one
Which is the best video player/decoder for PC?
By Marione in forum Software PlayingReplies: 8Last Post: 26th Nov 2010, 12:31 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 01:00 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 06:12 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
