I am using tmpgenc dvd author to convert mpeg to dvd using dvd+r. When i go to begin output it and asks me to create a folder in the drive it says it cant create it. Any ideas on how to fix this?
Results 1 to 10 of 10
I am using verbatim dvd+r 8 x with an NEC 3520A dvd drive. When i click on the drive it says e: is not accesible. Incorrect Function.
i just tried that and when i went to write dvd folder to dvd it said the dvd writing tool has encountered a problem and needs to close
This is what i've done so far, i added the mpeg file in source setup then in output i made an output folder in my documents then i went to write dvd folder to dvd r/rw and browsed for the folder i just created in my documents, selected the recorder and then clicked on write dvd
Move the VIDEO_TS and AUDIO_TS folders out of My Documents to somewhere else on their own (I suggest you make a new directory off your C: and drop them in there) and then try it. When you select the folder as source, you've got to select the folder above the VIDEO_TS and AUDIO_TS folders.
If in doubt, Google it. -
I've tried doing that but when i go to write dvd it says dvd writing tool has encountered a problem and needs to close
Try outputting as an ISO file in DVD Author and then burning with DVD Decrypter.
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 02:34 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Can I convert BD .mt2s files to MPEG-4 AVC/H.264 using TMPGEnc 4.0
By EdinburghKev in forum Blu-ray RippingReplies: 3Last Post: 20th Nov 2008, 10:10 -
tool to convert dvd to mpeg-1
By sumeshkri in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 04:29 -
Convert DVD to MPEG files....
By w@ntonsoup in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 11:12
