http://www.insaneness.com/ac3.html
Is that still necessary to install? If so, should you still install it w/the QT mpeg-2 component?
Also, is it necessary to install the DivX AND the XviD plug-ins?
#1. If you want to be able to play AC3 audio in QT, and you
do not have A.Pack installed, then yes you will need it.
And by all means, Yes Yo should also install the
QT-mpeg-2 playback plug-in.
#2. Yes, neither will interfere with the
other, and will insure you can play back
a wide range of .avi files in QT.
Plus, the 3ivx plugin will enable you
to export your video at a very HQ
close to the original source."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
thanks terryj!
I'll install both avi codecs [divx/xvid], the AC3 component, and the Flip4Mac WMV player.
Hopefully that will cover pretty much everything :X
Component to VGA
By aznSzeto in forum Newbie / General discussionsReplies: 4Last Post: 23rd Feb 2012, 22:31 -
DVI to Component
By Darth Paris in forum Media Center PC / MediaCentersReplies: 1Last Post: 10th Jun 2009, 11:13 -
HDMI vs Component.....
By snadge in forum DVB / IPTVReplies: 6Last Post: 27th Feb 2008, 17:02 -
1080i over component
By J. Baker in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jan 2008, 18:39
