Your opinion about the dvd player in the subject.
Problems ? Pros and cons?
Tnx
Alex -
I think its a great player for the price.
Pros:
Will play anything I've tried: vcd, svcd, dvd, cd-r, cdrw (any brand)
It plays Roxio winoncd music cd's (MP2) and photo albums
Its supposed to read dvd+rw (I haven't tried this yet)
Its supposed to read dvd-r (I haven't tried this yet)
2 scart connectors
You can use the remote to change region
Cons:
no onboard dolby digital or DTS decoders
Only allows about 25 region changes
Doesn't play MP3's -
I can confirm that it reads DVD+RW (tested with DVD+RW authored by me) and DVD-R (tested with a disk not authored by me and burned with the Pioneer AO3).
<font size=-1>[ This Message was edited by: Vulcan on 2001-12-13 10:44:01 ]</font> -
two of the cons above are rather small..
no onboard dolby digital or DTS decoders - guess, if you have a amp that can give you the Surround experience it can hadle the decoding it self. no need for it in DVD player
Doesn't play MP3's. Does ppl actually use this? i use my comp, using DVDplayer for mp3 is not very smooth..
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
Hey Vulcan, what colour was the burnable side coz I've tried two DVD-R's in my Philips 711DVD player and they didn't work but worked on my PC. The DVD-R's were made by TDK and were purple (burnable side).
Cheers.
I don't know the colour but since I did a test to see if I should buy the Pioneer burner (I ended up with HP DVD+RW instead) I wrote down the brand and number, Pioneer DVD-R disk, DVS-R470SDF.
The disk played well on my DVD (firmware 7.12. There is a newer firmware but I have not upgraded). My player is bought in Sweden (it's regionfree and plays both European and US disks) but I guess there should be no difference between European and other models as regards compatability for playing DVD-R.
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
DVD Disk Lock??? i locked my dvd player i need password! (PHILIPS DVP3520)
By kamzo91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Aug 2010, 15:14 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Is it possible to have G.711 audio in an H.264/mp4?
By Jean777 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2010, 17:53 -
Repairing the DVD Drive -- Philips PET 1000 Portable DVD Player
By ORSteve in forum Portable VideoReplies: 1Last Post: 13th Aug 2007, 13:45
