hi, i got a lg dvd burner and i am trying to burn dvd avi or mpg but i can not find a way to do it. I converted the avi into dvd and then tried to burn it but it doesn't work. Can someone help me letting me know how to burn a film in avi or mkv or mpg onto a dvd
Use an "Authoring" application to properly create your DVD.
There is a free Trial of Ulead's DVD MovieFactory -- ttry it to see if it does what you want...
ulead.comGeorge -
You take your MPG or AVI which should already be at the proper resolution, conver any AVIs to MPG2 with TmPGenc or simmilar, drop the file into an authoring program, choose from the many, TDA is good to start will. Create menu and links and or chapters, test / preview, output either directly to disk ( risky ) or to ISO or AUDIO_TS / VIDEO_TS folders for later burning with Decrypter or Nero or whatever suits you.
This was a very generic answer because you did not provide enough detail.
Make believe you are writting up a police report for the dicks. EVERYTHING should be included no matter how insignificant it may seem to you. It will help to eliminate back and forth replies trying to pull new details with each repply. We do want to help,,, really!!No DVD can withstand the power of DVDShrink along with AnyDVD! -
hi jtoolman2000, i am a real beginners so sorry for me being dumb but i download the TmPGenc you told me about . I also downloaded all the program indicated in the user guide of TmPGenc on this site (GSPOT2,Virtual, Ac3Fix) it is quite complicated. To i need all that? I can not seem to use TmpGenc. I copy a movie an avi video, 697 mb. I saved it on my desktop.Now all i want is to burn it on a dvd using a external dvd burner (i have a laptop) LG on dvd-r and be able to read it from any dvd player but i always have a problem doing so. Can you be specific in your explaination how to do so and how to use tmpgenc. The program refused my avi document saying there were no support. thanks
Get VSO Divx to DVD. Free.
Use it to convert the video to dvd structure.
Burn with whatever you currently use.Cheers, Jim
My DVDLab Guides
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
