hi friends, I'm trying to encode my vob's files into divx using AutoGK and divx codec 5.2.1 but always my pc hangup in the first pass, I only can reboot because my pc completly hanged.
Do you have any idea why is happening this to me? and any idea of how can I solve this?
Thanks a lot for your help.
Hernan Batista[/b]
Your CPU may be overheating. I use a program called SpeedFan to check it's temperature, you can also control fan speed with the program. Using AutoGK heats up my CPU more than anything else that I use on my computer. You may need to better ventilate your computer - put a better fan/heatsink on you CPU, etc.
what is your room temperature?? if the avg temp in the room is quite hot then it takes even less time/load to heat up the CPU.. try running prime95 (?) or getting excel to calculate 22/7 to 8million decimal places for around 24 hours...
The electronic components of the power part adopted a lot of Rubycons.
AutoMKV vs AutoGK (xvid encoding quality)
By dphirschler in forum Video ConversionReplies: 27Last Post: 7th Sep 2011, 11:43 -
Encoding .TS to .AVI--Is AutoGK the best for it?
By babypotato in forum Video ConversionReplies: 5Last Post: 1st Aug 2011, 03:08 -
autoGK started encoding out of sync
By octeuron in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 15:19 -
Encoding single episodes from disc with AutoGK
By stantheman1976 in forum DVD RippingReplies: 8Last Post: 20th Oct 2008, 19:12 -
AutoGK encoding options
By MyBigToe in forum DVD RippingReplies: 2Last Post: 3rd Mar 2008, 11:47
