I just wanted to let you guys know that having now used a Tenlab TR11-svhs standards converter,Sansung 300Wvcr,Panasonic ag1-W1vcr and Canopus Procoder express and Tempgenc express for software.
The best has to be Procoder, but it takes time, so hardware solutions are attractive:-
The tenlab produces too much image change, the panasonic I have is quite old and playing a tape on it was not great, so I just tried the Samsung and Panasonic as pass throughs ntsc in pal out for instance from a JVC sr 10u to either my advc300 or a dvd recorder and got great results, the Panasonic is about 15% better I would say.
Another way you can do it, is to use a dvd recorder, RJ/Daytek to name but two which deal with pal/ntsc convert and connect your vcr to the input and use the dvd recorder as a converter to another vcr or dvd recorder.
Hope this helps you guys, thanks
Results 1 to 1 of 1
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
