    Nov 2004
    Brazil
    hi Pals...
    I'm having 2 little doubts in my mind about which is the best way to export a file from FCP to DVDSP. I was thinking that the only way would be exporting as an MPEG2 file using QT conversion or COMPRESSOR. But yesterday after finishing the edits of a movie that I converted from a VHS tape using my Canopus 300, I by mistake exported it as a simple QT MOVIE and it opened in DVDSP I built, Formated and burned the DVD without any problems. Did DVDSP converted the movie to an MPEG2 file during the build process ? Or what ..?
    Second doubt: When exporting using COMPRESSOR, do I have to choose the presets (60, 90 or 120 minutes) thinking on the duration of the movie that I'm exporting or in the final duration of the DVD with others movies and assets ?
    Thanks Pals....
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Ok, first pick up a copy of
    either Jerry Hoffman's book (STF
    to find the link) or VQS: DVD Studio Pro 3 by Martin Sitter,
    as both
    books cover what I'm going to say:
    1. Yes, DVDSP will encode to Mpeg-2
    upon Build any non encoded items such as Qt movies,
    dv streams, aiffs, etc.
    optimumally you want everything to already to be
    in .m2v and .ac3 BEFORE importing into DVDSP3
    to save time, but for short projects, its apples and
    oranges really if you do it beforehand or not.
    2. The preset you use will be one you custom build that
    will be based on the TOTAL amount of video in your project,
    including inbetweens, menu loops, intros, bonus tracks etc.
    Go to versiontracker and get a Bit Rate Calculator to add
    up and figure
    the correct min Mbps you will need to set your preset to.
    Take into account also if your video has a lot of action or
    is something like a reality show. lots of action, you need
    to go for a Variable Best setting in Compressor, reality
    show, go for a Constant Bit Rate in Compressor.
    Exporting from FCP should ALWAYS be done as
    Export--> Quicktime Movie and make the file self contained.
    Drag and Drop this into Compressor, set with your custom preset,
    and your done.
    Nov 2004
    Brazil
    thanks for the tips....I will look foward for the books you mentioned at the amazon website, because as I'm not in US I think it would be difficult to find them around here.....
    I'll also go to versiontracker to find a Bit Calculator.
  4. Member terryj's Avatar
    Amazon.uk links:
    Jerry Hoffman
    DVDSP3 VQS
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
