Is it possible to capture analogue via a Firewire card please?
I do it through my camcorder anologue in & out and then into my firewire card....
There may a anologue converter which has a firewire cable output... -
No, it's a digital input.
You can, of course, convert analog to digital with a exterior box or a camcorder with passthrough and feed that into a Firewire DV input. -
I have a Sony 95E Hi8 recorder which only has analogue out - so I guess in & out will not work. Will look for an analogue to Firewire converter if there is one.Originally Posted by LOWTECH
You can also capture via USB (2.0), there are some analog capture cables, which are not expensive. I don't know how it is with quality, though...
Es un pueblo orgulloso de una ceiba... -
I don't like the USB solution overall. But that has nothing to do with USB itself, it has to do with the offering solutions that use the USB connection.
@devdeep: There are 2 ways to do this: Through a digital videocamera than has a video in and DV out or (a far better way) using special - for this task - devices, like Canopus 100/50/55 or Datavideo
Overall DV is great for NTSC and excellent for PALLa Linea by Osvaldo Cavandoli
Pinnacle makes a device called a Moviebox that can be purchased with either a USB or firewire output. You can input analog to it.
Tiger Direct sells refurbished ones for $99. Otherwise, I think they're around $150-$200, depending upon who sells them.
analogue video capture from ultrasound machine without pc
By vito321 in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2012, 14:02 -
Analogue to Digital capture software
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 16th Jun 2011, 12:10 -
Analogue Capture problems
By Lensmeister in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2009, 06:20 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 19:29 -
Analogue Capture
By Sonnyt in forum Capturing and VCRReplies: 3Last Post: 26th Mar 2008, 20:49
