I have an xvid/avi file that I have converted to MPEG-2 720x576 25fps VBR 8000kbps, Layer-2 48000Hz 384kbps with TMPGEnc Plus. I then import this file into TMPG DVD Author, create menues and burn the resulting audio_ts and video_ts folders to a DVDR. Picture is fine but the audio is not there if I play the dvd on my Yamaha home theatre system. If I turn on the TV's volume everything is fine. Where am I making my mistake? Do I have to convert the avi file in a different way? Are there any plug-ins that I need?
Kal
do you get any audio on your computer?
have you tried wav or ac3 instead of mpa/mp2 audio?
have you tried change the audio settings on your dvd player, something like output mpa/mp2 to wav/pcm. -
There is sound when played thru PowerDVD on my computer. I have tried wav with no success. I can get sound on my standalone player if I change the sound output to PCM but that means problems with a normal dvd unless I keep chainging back and forth, doesn't? I would prefer encoding the dvd correctly from the beginning.
Kal -
Use ac3 then. You get the tmpgenc ac3 plugin for tmpgenc dvd author.
read about the dvd audio standards:
https://www.videohelp.com/guides.php?guideid=445&howtoselect=3;56#445 -
and where do I get that? I have one version but dvd author refuses to recognise it. Hjälp snälla!
Kal
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 15:38 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
