Hi,
I have avi file (xVid), with AC3 (6CH) which I wish to convet to DVD Video with 6CH.
In short this is what I did:
1. I seperated the audio with VirtualDubMod.
2. I converted AVI-->m2V with TMPGenc.
3 Tried to create DVD with TMPGenc DVD Author.
I found out that there is a time difference between the audio and the video of about 8 seconds. It's not DVD author fault, since the problem is in the audio creation.
Of course if I try to create DVD there is no audio/vidoe sync.
In the original avi everything is OK.
Any ideas how to overcome this problem?
PS I hope I am asking in the right forum.
Thanks.
did you do any framerate conversion??? like pal to ntsc or ntsc to pal? 23.976 fps to 25fps or 25fps to 29.97 or something?
No I didn't. The movie was originaly and now 25.00 fps.
PS. I don't think newbie/general discussions is the right forum for this thread. With all the respect this aint newbie question and certainly not a general discussion. You moved this thread to the wrong forum. -
PGCDexum can rip AC3 only from original DVD (using the IFO), I have AVI (xVid) so it seems it can't help in ripping the AC3.
I need another tool.
AVIMux GUI result in mka file, which I can't see what it is good for.
Thanks again for your help. -
OK, the problem was solved.
Just for the info of anybody who might read this post. I used DVD lab, which has the functions of audio delay. I rebuilt the AC3 file and added delay of 8000ms. Everything is OK now.
Another option was found here: AC3 Delay Corrector V2.0 - http://home.t-online.de/home/520072193568-0001/
Good Luck.
ac3 audio and xvid video in avi out of sync
By socrates in forum Video ConversionReplies: 10Last Post: 15th Jul 2011, 21:58 -
MKVMerge problem , audio out of sync - says This AC3 track contains 227 byt
By PSPGamer in forum DVD RippingReplies: 2Last Post: 20th Apr 2011, 16:38 -
AC3 Sync problem out of MKV file
By betão in forum Blu-ray RippingReplies: 7Last Post: 9th Jul 2010, 22:30 -
Problem with audio gradually going out of sync in ts file (captured video)
By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2010, 11:12 -
Mencoder // ffmpeg flv file Audio-video sync problem
By krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 09:13
