  1. i burnt my dual layer dvd the other day i noticed it froze twice during playback i assume this happened because of the layerbreak correct??
    should i be burning dual layer media with something besides nero oem suite??
    i dont backup any dvd movies to dvdr what i do is record the program i want with the dvd recorder and then reauthor them with tmpgenc then finally burn them with nero express at 2.4x speed.
    the reason why i burn with nero is because i am able to fit more data on the dvd than with tmpgenc dvd author weird huh?
    what should i burn dual layer media with just to be on the safe side i know i heard something about burning with dvddecrypter but i dont backup dvd's to ISO mode so using crypter is not an option not unless there is a guide i am not aware of??
  2. You can use IFOEdit->Tools->Create Image to make an ISO,the drawback is you lose all other folders(AUDIO_TS,JACKET_P,etc).Another option is to use RecordNow Deluxe or Prassi Ones.
    Here's another:use DVDShrink to shrink and burn with DVDDecrypter.
