Closed Thread
  1. I have never had this problem but I recently bought Knight Rider Season 2 and wanted to copy the discs for other people. Anyways after using DVD Shrink it seems to rip and burn the movie fine, but when I try to play it on my DVD player or PC DVD player it tells me I have no disc.
    I am assuming this is some new copy protection, Is there a way to solve around this issue? I have copied DVDs in the past with no problem.
    Thanks in advance!
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Cobra
    ***Warning Expired***
  2. Ahhh....you shouldn't make copies of pressed DVD's for friends,in the future don't tell us that.
    It could be a bad burn,use IsoBuster to make sure there is data on the disc.
    BTW...was the DVD a different format(PAL,NTSC) than yours?
  3. its in NTSC format, i'll try the program you mentioned and let post the results.
  4. I get a no media present message when I use ISO Buster , the DVD rom drive also sounds like it is trying to look for stuff on the disc.
  5. It could be the "Jumping Boy" copy protection. The same thing happened to me when I backed up my collection of the mini-series "Taken". What you need to do is change the "Unreferenced Material" Folder to a Still Image in Shrink. Then the burns should play fine.
